5 members (55shaker, Rich'sToys, 59 fleet, pdlightning, 1 invisible), 140 guests, and 5 robots.
Topics128,077
Posts1,056,032
Members48,433
#952773 06/26/2013 2:53 PM
Hi all! Re-powering my '38 1 1/2 ton dump. Donor engine ID is 'F02071' Casting number '3769716' says it's a '58-'62.(Thanks, GMONIZ!) Any way to narrow it down? Primary questions are 'Water pump-short shaft or adaptor plate?' Where to buy?
'Do I need to swap the flywheels to run the original starter?'
I'm reviewing posts to see if I'm missing things...bet I am! Any pokes in the right direction appreciated!
Tom
Tom,
Find and post the other casting codes:
head casting code
head date casting code
block casting code
block date casting code
In F02071, is the last character a 1, or a J, or an L?
I prefer using this adapter plate. You can then use your original water pump and the pulley will be same width as generator/balancer pulleys. Also, that plate locates the fan blade in the optimal position relative to the radiator.
Use you original 6v starter with original flywheel, as long as the bolt pattern of flywheel to engine matches.
1942-62 only on flywheels for correct fit. 1938-41 have the same bolt pattern but use 3/8" bolts to attach to the crank instead of 7/16" and the pilot hole in the center is also larger.
In a pinch the 3/8" bolt holes can be drilled out, the center pilot may not be that big a deal as the three line-up pins keep the flywheel in position. I have seen it done.
My Blog
Thanks for the reply!
Other numbers are: CON4 B52
19
He says there is a tag riveted to the block that says 'Power Pak' J039133
I'm assuming that's a factory re-build?
Thanks for the help! (He's unable to get the head numbers today.)
Tom
Oh, on the ser. no. 'F02071' the last could be a '1' or an 'L', probably not a 'J'. If it's not too much trouble, let me know all three, then when my buddy gets back to his shop, I can get it figured out. Hard to tell till I get it here. I ordered the adapter plate recommended by tclederman "Boltergeist" I should be able to get both waterpump gaskets from FLAPS.
Thanks!
Tom
Usually:
J = 3100-3800 series 235 regular production
L = 6000 series
T = 9000 series
I am not sure what engine was standard for 6000 and 9000 series (it might depend on the year and would also depend on the options).
