| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hi all! Re-powering my '38 1 1/2 ton dump. Donor engine ID is 'F02071' Casting number '3769716' says it's a '58-'62.(Thanks, GMONIZ!) Any way to narrow it down? Primary questions are 'Water pump-short shaft or adaptor plate?' Where to buy? 'Do I need to swap the flywheels to run the original starter?' I'm reviewing posts to see if I'm missing things...bet I am! Any pokes in the right direction appreciated! Tom | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tom, Find and post the other casting codes: head casting code head date casting code block casting code block date casting code In F02071, is the last character a 1, or a J, or an L? I prefer using this adapter plate. You can then use your original water pump and the pulley will be same width as generator/balancer pulleys. Also, that plate locates the fan blade in the optimal position relative to the radiator. Use you original 6v starter with original flywheel, as long as the bolt pattern of flywheel to engine matches. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1942-62 only on flywheels for correct fit. 1938-41 have the same bolt pattern but use 3/8" bolts to attach to the crank instead of 7/16" and the pilot hole in the center is also larger. In a pinch the 3/8" bolt holes can be drilled out, the center pilot may not be that big a deal as the three line-up pins keep the flywheel in position. I have seen it done.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Thanks for the reply! Other numbers are: CON4 B52 19 He says there is a tag riveted to the block that says 'Power Pak' J039133
I'm assuming that's a factory re-build?
Thanks for the help! (He's unable to get the head numbers today.)
Tom | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Oh, on the ser. no. 'F02071' the last could be a '1' or an 'L', probably not a 'J'. If it's not too much trouble, let me know all three, then when my buddy gets back to his shop, I can get it figured out. Hard to tell till I get it here. I ordered the adapter plate recommended by tclederman "Boltergeist" I should be able to get both waterpump gaskets from FLAPS.
Thanks! Tom | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Usually:
J = 3100-3800 series 235 regular production L = 6000 series T = 9000 series
I am not sure what engine was standard for 6000 and 9000 series (it might depend on the year and would also depend on the options).
