8 members (mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, homer52, 1 invisible),
102
Mod | | | Forums66 Topics128,089 Posts1,056,137 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 18 New Guy | | New Guy Joined: Jul 2010 Posts: 18 | I have a 46 Suburban with the clam shell rear door configuration. The flip up top half has been fitted with a pair of large exterior hinges that are drilled through the roof. The original slots for the original hinges are still intact and I was wanting to use them once again. are all the 47 hinges the same for all the rear door assemblies, or are these two hinges unique in someway? Thanks in advance.
Change is Opportunity
| | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I was under the impression that the 46 hinges were different. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I can get you the part numbers for the 46 hinges if you need them. They are stamped on the back of the attaching plate. | | |
