0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
#95261 04/02/2006 3:39 PM
Can anyone tell me where I can buy a 12 volt conversion kit for my 52 chevy PU?
#95262 04/02/2006 3:53 PM
Riding in the Passing Lane
I don,t believe there is an actual kit for it. You can do a search & get all the info you need and then post any questions you have on this forum.
1972 Chevy c10 Cheyenne Super
#95263 04/02/2006 6:49 PM
#95264 04/03/2006 4:32 PM
Fifth Avenue has all of the parts you need and will help you with questions, their web site is www.fifthaveinternetgarage.com or call them at 785-632-3450
#95265 04/03/2006 7:02 PM
Junior Member
Junior Member
When I made my change over Alan Horvath's page had the info I needed, try: http://www.alanhorvath.com/54chevy/mad_electrical.php
I ordered the manual by MAD and followed the instructions, it was pretty easy to do. Get yourself an AC DELCO 94 amp alternator for the conversion, as well as the other parts mentioned previously.
#95266 04/03/2006 8:45 PM
Why are you going to 12 volts ? Now all you other bolters don't get ahead of me on this, you know where im going with this :rolleyes:
Cecil..........
#95267 04/03/2006 8:47 PM
Change over involves a few things- Ingition circuit, charging circuit, guages and sending unit, and bulbs.
12 bulbs in guages, tail lights, headlights, etc...
voltage drop (runtz) for ammmeter, gas guage, fuel sending unit, radio and possibly heater blower motor.
Voltage drop for coil.
You can use a 74 monte carlo alternator, but they are only 55 amp. If you can find one that wires up the same with 90 amps, great!
