7 members (Wally / Montana, greenie-reddy, sron48, padresag, walter74, Wayne67vert, Shaffer's1950), 92 guests, and 5 robots.
Topics128,269
Posts1,058,399
Members48,485
I just got this 65 truck and it has new halogen bulb conversion. It has 60 grille installed. I have one light only on low beam working bright(DS) and on high beam two on other side(PS) are dim. DS while on high beam, only the outer headlight is on and bright. Where do I start checking? Any help/info appreciated.Thanks
start with all the grounding points on both sides, and I believe there should only be one of the 2 on each side for brights, the other one of the 2 should be low beam only
