7 members (Peggy M, joe apple, WICruiser, baldeagle, Bill Hanlon, dt235sd, Stovebolt48), 118 guests, and 3 robots.
Topics128,038
Posts1,055,471
Members48,424
#95253 04/01/2006 9:30 AM
Junior Member
Junior Member
WERE CAN I FIND THEM
#95254 04/01/2006 1:06 PM
Check the sponsor first..American Classic
or
Fifth Ave Antique Auto Parts (Randy's original design?)
or
Patrick's (I got mine here )
or
Jim Carter
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#95255 04/01/2006 1:06 PM
what are you wanting to do?? if going to 12v and wanting to use to reduce dash and such,,and good parts store,,,NAPA is a good bet,,tell them what it will be used to reduce...doc
#95256 04/01/2006 4:56 PM
rollinlow.
If you find a 12v to 6v Runtz resistor at NAPA, please post the part number here. This would surely be of interest to many people.
Tim
#95257 04/03/2006 3:56 AM
Junior Member
Junior Member
all napa had was the ceramic ones iv done checked there
#95258 04/03/2006 4:38 PM
I am the original designer of the Runtz which i engineered back in 1992. I have them as do the dealers mentioned in a previous post. NAPA does not sell them and only offers the ceramic resistors which are not a true solid state "voltage regulator like the Runtz. The Runtz came about because I got tired of fighting with the ceramic ones which proved to not be very accurate. Also the ceramic ones have no circuit protection like the Runtz...Thanks Randy
#95259 04/19/2006 2:28 PM
1 Offline
old ford trucks and some cars in the 60's used them on their gauges the newer style had the pin style connector.lots of dead fords lying around check it out! use # 2 for a dead ford. pull-a-part!!
#95260 05/05/2006 3:49 AM
I was going to say......contact fifthave, but Randy beat me to it. I still have mine running after 3-4 years and zero problems.
Craig
Craig
