7 members (gswbbc, Hanks custodian, BC59, 55shaker, dt235sd, wilbur53, Lightholder's Dad),
76
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95253 04/01/2006 9:30 AM | Joined: Jan 2006 Posts: 7 Junior Member | | Junior Member Joined: Jan 2006 Posts: 7 | | | |
#95254 04/01/2006 1:06 PM | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | Check the sponsor first..American Classic or Fifth Ave Antique Auto Parts (Randy's original design?) or Patrick's (I got mine here ) or Jim Carter
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
#95255 04/01/2006 1:06 PM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | what are you wanting to do?? if going to 12v and wanting to use to reduce dash and such,,and good parts store,,,NAPA is a good bet,,tell them what it will be used to reduce...doc | | |
#95256 04/01/2006 4:56 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rollinlow.
If you find a 12v to 6v Runtz resistor at NAPA, please post the part number here. This would surely be of interest to many people.
Tim | | |
#95257 04/03/2006 3:56 AM | Joined: Jan 2006 Posts: 7 Junior Member | | Junior Member Joined: Jan 2006 Posts: 7 | all napa had was the ceramic ones iv done checked there | | |
#95258 04/03/2006 4:38 PM | Joined: Jan 2000 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 124 | I am the original designer of the Runtz which i engineered back in 1992. I have them as do the dealers mentioned in a previous post. NAPA does not sell them and only offers the ceramic resistors which are not a true solid state "voltage regulator like the Runtz. The Runtz came about because I got tired of fighting with the ceramic ones which proved to not be very accurate. Also the ceramic ones have no circuit protection like the Runtz...Thanks Randy | | |
#95259 04/19/2006 2:28 PM | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | old ford trucks and some cars in the 60's used them on their gauges the newer style had the pin style connector.lots of dead fords lying around check it out! use # 2 for a dead ford. pull-a-part!! | | |
#95260 05/05/2006 3:49 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I was going to say......contact fifthave, but Randy beat me to it. I still have mine running after 3-4 years and zero problems.
Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
