8 members (Gdads51, Wayne67vert, MickeyP, Cletus1950, Hotrod Lincoln, UtahYork, TexasJim50, baldeagle),
106
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | I'm going to have my panel body dipped in what is supposed to be a non-destructive process. I'm told after the dip the body will be sprayed to prevent flash rust. I don't know how long that will last and I don't know what to do to treat the metal before I apply a good epoxy primer, probably eastwoods. I need to know a step by step approach to getting the body cavities rust proofed as they are unpaintable hidden area and if I can do the weld repairs after spraying with the epoxy. Any help appreciated.
Still trying to get ole Betsy back on the road.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | As if it were possible... get in touch with an Eastwood PAINT rep and follow their procedure cause not a lot of epoxies want to share the metal with dip from my reading.
I'd be more inclined towards Ospho (and neutralize) the hidden area's and sand blast the rest. Then dip in epoxy... or brush/pour it. I'd feel safer later on.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ask the place what the after-spray is, if it's phosphoric acid [should be], ask them to be liberal with it, including spraying inside the rear body cavity thru the little covers in the sidewalls - be a good idea to drill some holes in those panels on the inside below the floor level so the cavities there drain well, they can be plugged later - phosphoric acid treatment will last a long time if kept totally dry, Florida humidity may defeat it
if the whole thing is well treated with phosphoric acid [Ospho as CASO says], epoxy will work, the trick is to make sure all the pinch welds are flushed out well so no stripper chem bleeds out under the primer - but you shouldn't count on doing your welding after epoxy unless you're also prepared to strip the epoxy off the area to be worked
Bill | | | | | Joined: Sep 2010 Posts: 1,717 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,717 | I'm going to have my panel body dipped in what is supposed to be a non-destructive process. Where are you having this done? I've been told very few are around anymore. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | If its to be a factory stock deal, don't drill extra holes less your planning to weld them up after wards. Eastwood has a spray deal that has flex wands for the tip, I was thinking about using it to apply epoxy in the hard to get to panels. Also was thinking about doing the phosphoric thing before the epoxy too. The place that does the job should know how to make sure theres no chem left in the pinchwelds etc. I think heating those areas would help.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | The place is here in south central Florida. http://www.autorestorationdepot.com/contact.htmlAuto Klassic Metal Clean, LLC or a google search on autorestorationdepot.com They have a package price for all the basic sheet metal and also individual parts
| | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Thanks all for the tips. I need to talk to the supplier/dipper and see what else they can tell me about the process. I sure don't want rust to bubble out after going to all this work.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... just as info for us guys it'd be nice to know what a package price would run for basic stuff. That way I can think about it or just plain forget it in the budgets. | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | Go to the link above and look for "prices" on the left side. It's their price list.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks Craig. I must have been half a sleep  | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | if the whole thing is well treated with phosphoric acid [Ospho as CASO says], epoxy will work, the trick is to make sure all the pinch welds are flushed out well so no stripper chem bleeds out under the primer - but you shouldn't count on doing your welding after epoxy unless you're also prepared to strip the epoxy off the area to be worked
Bill Check the data sheet for your epoxy primer. Some of them have adhesion problems if used over phos acid. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | As I understand it the proper way to neutralize the ospho (phosporic acid) is to wash it off while it is still wet/active. To me that means I may apply it and let it dry three or four times if I'm picky... I mean lazy and when I'm ready I re-apply it and let it set a few minutes to reactivate the residue and the pores of the metal  and then wash it off with plenty of water and a red scotch pad. good to go.
