| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | I'm sure this has been talked about, but where can one find new or nos engine pans for the 216's or later '58 235 engines? Few days on the inner web search and Stovebolt search (40 pages) leaving me bug eyed and puffy fingers.
There is not a tool made that if you don't try hard enough you can't break! 1952 3100 261 T5 3.08 Gov Locker
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Pans come up on eBay now and then but that or a swap meet is about it. You could also post a want add here in the Swap Meet section.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Agreed, I see pans on ebay all the time.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I do not believe a 216 pan is compatible with a 1958 235 pan. If you need and want a 216 pan, I have parts available. Jerry Jerry
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jerry is correct. Earlier oil pans have straight sides, 1956-62 oil pans have a bulge in them near the center. | | | | | Joined: Apr 2012 Posts: 44 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 44 | Thanks for the replies. The 216 or the 235 aren't marking territory yet, but when I pull them down in the near future I wanted to replace their pans.
