1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95231 03/29/2006 10:08 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Does anybody have any advice - including don't do it - on using 12-V LED bulbs for turn indicator lights?
Never start vast projects with half vast ideas.
#95232 03/29/2006 10:41 PM | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | You can use them just fine. The problem you might run into is they won't flash. If that is the case you"ll need an electronic flasher. The led lites have a very low draw and it's not enough to activate a standard flasher.
hope this helps. | | |
#95233 03/29/2006 10:45 PM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I tried them and discarded the idea. wouldn't work properly, not counting the flasher problem. bought new led complete tailights and work great. the bulb alone didn't get it | | |
#95234 03/30/2006 7:09 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I have a pair of them that I'm going to use - mock-up tests work fine. Quite a bit brighter than the incandescents. | | |
#95235 03/31/2006 3:47 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Here is some really good advise on 6 volt LEDs. The same would apply to 12 volts. It's worth reading if you are wanting to try LEDs. http://www.highspeedmotors.com/Webled.html
#95236 03/31/2006 10:07 PM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Got LEDs on my motorcycle,,,,love 'em!
Keith If it were easy they'd have grade schoolers doing it! | | |
#95237 04/01/2006 12:30 AM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | electropods i placed three of these inside of my stock tail lamp holders and they are great http://www.tricktape.com/index.asp?PageAction=VIEWPROD&ProdID=4849 http://motorcyclecity.com/Parts/50ZX3869U.html I paid about $6-7.00 each for them. wired them up for stop, tail, blinkers.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#95238 04/04/2006 10:39 PM | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Thanks. Good information. The Highspeed Motors site was great and thanks for telling about the electronic flasher unit.
#95239 04/04/2006 11:49 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
#95240 04/15/2006 12:55 AM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Anybody know where I can buy one of those electronic flashers for 6 volt systems. Before I bought some LED lights from HighSpeed Motors (mentioned above), I called the local NAPA store and they assured me they had them. Unfortunately, when I went to buy one, it turns out they don't. I want to replace all of my turn signal bulbs, so it sounds like I will need an electronic flasher.
My dad always told me, "Don't force it, get a bigger hammer".
#95241 04/16/2006 6:32 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | billydon make sure your LED's work w/ running as little as 6 volts. I do not know of ANY 6 v LED's
#95242 04/16/2006 6:38 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Originally posted by carolines truck: I do not know of ANY 6 v LED's http://www.highspeedmotors.com/Webled.html
#95243 04/16/2006 6:47 PM | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Caroline's Truck,
Tiny's right. Highspeedmotors is where I bought the 6 volot LED's. They are a direct swap for the 6 volt bulbs in my taillights. I've replacecd all of the rear bulbs, and the LED's are working. But as I understand it, once I replace the front bulbs, the flasher won't work.
#95244 04/16/2006 6:52 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you may only need to have one ''regular'' bulb (somewhere in the system) so the flasher can sense the resistance and it should work
#95245 04/16/2006 9:14 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | BillyDon, Carolinestruck is correct. This is a cut & paste from the highspeedmotors site: 6. If you choose to use these 6 Volt LED bulbs to replace all 4 of your Turn signal bulbs, the old style flasher units will not turn the bulbs on and off. There is just not enough current flow to heat up the flasher unit. There are a few ways around this. You can pigtail a single incandesant bulb from each side of the circuit (for example in the trunk, under the dash, or in the tail light housing), or wire in a dropping resistor. As long as there is one of the old type bulbs in the circuit, these LEDs will flash. They will work just fine, with no alterations to your wiring, if they are used for either only front or only rear turn signal bulbs.
#95246 05/11/2006 12:16 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Using the type that are bulb replacements won't work with blue dots, I know, I tried it. Also try checking in the "tuner" aisle at your local parts store for electronic flashers.
Bill Burmeister | | |
#95248 05/12/2006 1:46 AM | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Hotronics www.hotronicsproducts.com [714]971-8543 makes no load LED flashers $35.00 so you don't have to splice the extra bulb into the wiring. Just got my new Painless Wiring catalog in the mail. they also have no load flashers for use with LED's. JimBo
Bubba
