6 members (geardaddy, 1955 1 Series, tclederman, Cosmo, baldeagle, 1 invisible), 75 guests, and 2 robots.
Topics128,015
Posts1,055,335
Members48,419
#95222 03/29/2006 4:07 AM
I am in the process of installing a new harness in my '63 and I've run up on a bit of confusion. I am upgrading to an internally regulated AC Delco 10SI 63 Amp alternator and I have one more connection than I expected. I understand the 1 (exciter), 2 (voltage sensing), and Batt (obvious) connections, but there is also a rather large bolt on the back of the unit that looks like it should have something under it. I suspect that is may be either a mounting bolt for a different application or a ground point. Anybody got any better ideas?
Daily Driver 63 C-10 LWB Fleetside
#95223 03/29/2006 5:40 AM
The three connections you mentioned are all there are:
[img]http://alanhorvath.com/54chevy/chevypics/wiring_1.jpg[/img]
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#95224 03/29/2006 9:47 AM
The bolt in the back is only for a mounting bracket. On some cars and trucks,there is a pivot bolt spacer with a strap connected to it that was attached to the bolt,so it wouldn't fall into the Twilight Zone when the pivot bolt was removed.Not critical on your truck.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#95225 03/29/2006 3:44 PM
Thanks guys.
#95226 03/29/2006 3:47 PM
I just thought of another question...since the case of the alternator is grounded through the mounting bracket to the block, can I use this bolt on the back of the alternator as a ground point for a portion of the harness?
