| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Fenton headers on a 1958 chevy 235 engine going into a 1951 chev 3800. Did test run today,6 miles around the country block. GREAT RUN, Except for carb adjust and timing issues. Fresh co0olant just added, temperature stayed at thermostat ed 180 degree, Oil pressure stayed pegging the old oil guage at 30 pounds. Pulled back into shop and a puddle showed up under truck. Rear driver side frost plug had sprung a leak. I want to install a temporary expandable plug in the leaking hole to try and get me thru summer. Question # 1, When I ask at parts store, What is the diameter of the frost plug holes? Question # 2 Does anybody have a pair of Fenton's for a 235 on the shelf. Would you PLEASE confirm the exhaust diameter to be 2 inches AND are the Flange bolt holes 3.25 inches apart. The shop making my exhaust needs these measurements to make me some exhaust pipes so if I can go to a car/ truck show next saturday. I would be forever grateful Thanks, Jerry
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I tried an expandable freeze out plug once and never again. It held for awhile but once it ran under pressure for a short time "pop" and out it came, along w/all my new 50/50 anti freeze. Wrestled a new steel plug back in and to my knowledge it's still holding.
Can't help on the headers, good luck. Dave
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | In the old days like around 1988 or so I got a nice expandable soft plug from napa it was all metal kinda all copper or brass looking, you just put it in the hole with some #2 and tightened the hex nut on the end and it held for years. Last time I asked at napa about them they looked at me funny.
Wow I found one I still had, made by Dorman products Pat number 3361288 I went to their site and nothin. That is typical anything that works good they stop making it.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I didn't measure the flanges as they are not on the shelf but on the engine but if you say 3.25 then thats it. I did measure the exhaust pipe from the Fenton and yes it is 2".
As for the "freeze" plug all I can add is that I've never seen a temporary anything that was worth a bucket of spit. Just fix it right and be done with it. | | |
