| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | I am almost done restoring my 1946 chevy 1.5 ton, But I am in need of a complete windshield, is there anywhere that I can order a complete ready to install windshield for this truck. I know that Chevs of the 40s has all the parts that I could assemble one piece by piece bt I am hoping to find somewhere that has a complete one. Thanks in advance. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | I recently bought one on eBay for my 46 GMC 1.5 ton. And I see them listed ever so often. 41 to 46 GMC and Chev are the same. I actually found mine on a search for 41 GMC. | | | | | Joined: Oct 2006 Posts: 163 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 163 | I haven't seen them as a preassembled single unit. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Very simple to put together. I took my frame sections, glass, and center bar to a local glazing shop. He used polyeurethane glazing compound to set the glass and assembled everything for me. I installed the Steeles Rubber gasket around the perimeter. You end up with a butt joint in the rubber which is glued together with 3M adhesive recommended by Steeles. | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | | | |
