12 members (Hotrod Lincoln, TUTS 59, Gdads51, KEVINSKI, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, Otto Skorzeny, 2 invisible),
149
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 10 New Guy | | New Guy Joined: Jun 2013 Posts: 10 | My new 1950 3100 has a tag in the door jamb on the drivers side with a serial number. I ran the number and it says it ays it's a 3/4 ton built in Janesville WI in May of 1950. Cool except that the sides of the hood have "3100" emblems and the wheel base is 116 inches. Unless I'm mistaken wheel base is measured center of wheel to center of wheel. I bought the truck with a title and retitled it when I bought it. Was there a short 3/4 ton made or do I have an incorrect data tag? Hmmm..... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Sounds to me like your cab has been replaced with one from a 3/4 ton. How many lug nuts? | | | | | Joined: Jun 2013 Posts: 10 New Guy | | New Guy Joined: Jun 2013 Posts: 10 | 6 lug nuts. I thought I knew something about these trucks until I bought one. Any light you can shed I appreciate! Thank you. Jim | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | a 3/4 ton would have 8 lug nuts. Also the back half of the drive shaft is open. (along with many other items) | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Easy to swap cabs and depending on your personal ethics to swap plates. It may be problematic if you should ever sell the truck. If you plan on keeping it forever it should not be an issue. A lot can happen in 60+ years, the fact there is no other serial number anywhere on the truck makes it pretty easy to swap. | | | | | Joined: Jun 2013 Posts: 10 New Guy | | New Guy Joined: Jun 2013 Posts: 10 | Thanks for the info guys. I'm not sure what happened. May have been inadvertent or may have been planned due to convenience, I'm not sure. I bought it titled and our dmv retitled it it my name so I may just let a sleeping dog lie and enjoy the truck. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, defiantly sounds like a 3100 that had a cab swap done or maybe they just swapped the ID tag??? Is it a five window?? If it was a three window might be that they wanted a deluxe cab.
Denny G
Denny G Sandwich, IL
