| | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95147 03/19/2006 12:54 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | just need to vent. spent 2 hours with generators this fine sat. a little tapping and prying got both pullys off. the bad gen droped the key with a poke of a screw driver. the gen i plan to use with my original pully, i can't get the key out of the armature shaft. finally gave it a rest and plan to maybe dril some small holes to hope to weeken the key enough. am not sure i waht to heat around the bearing on the gen. arr!
"It ain't a truck if you can't hose out the cab."
#95148 03/19/2006 1:15 AM | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | small sharp chisel and hammer will remove your key..doc | | |
#95149 03/19/2006 1:42 AM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | thanks, doc. that is what i been thinking, first rule; "always use the right tool for the job". screw driver chisels, don't do it. parts store is open sun, i will get a small cold chisel, all i have now are wrong size. good night all.
