7 members (51sub, 41 chev, WICruiser, Oldpickupman, Gdads51, Charles in CA, 1 invisible), 92 guests, and 3 robots.
Topics128,265
Posts1,058,360
Members48,485
#95147 03/19/2006 12:54 AM
just need to vent. spent 2 hours with generators this fine sat. a little tapping and prying got both pullys off. the bad gen droped the key with a poke of a screw driver. the gen i plan to use with my original pully, i can't get the key out of the armature shaft. finally gave it a rest and plan to maybe dril some small holes to hope to weeken the key enough. am not sure i waht to heat around the bearing on the gen. arr!
"It ain't a truck if you can't hose out the cab."
#95148 03/19/2006 1:15 AM
small sharp chisel and hammer will remove your key..doc
#95149 03/19/2006 1:42 AM
thanks, doc. that is what i been thinking, first rule; "always use the right tool for the job". screw driver chisels, don't do it. parts store is open sun, i will get a small cold chisel, all i have now are wrong size. good night all.
