2 members (78buckshot, Wheelie),
131
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | My truck runs beautiful except the throttle sticks. I've got it set to run a 500 rpm at idle but when I pull up to a stop light/sign it sticks at about 1,000 rpm until I goose it then it will release and go down to 500. It is an annoyance to be sure and is slightly dangerous when I'm braking and have to get off the brake to goose it.
My question: What would you all recommend to lube the "joints" in the linkage to help with this? Also because of all of the work I did detailing the truck I don't want grease all over at least until I've had it for a few years if possible.
Thanks in advance!!!
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | I should add it is a stock Rochester B single barrel carb with manual choke and the choke is definitely not the problem.
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Tom, Don't you see what's happening? Your truck doesn't want you to stop giving it attention. You've worked on it all these years and now you're done. Seems the truck wants you to keep wrenchin' - it likes it! LOL!
I'll be watching for the answer and lube my linkage with the same stuff.
Jay | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Jay,
That was funny. I read it to my wife and she even laughed. I hope it's not true.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | shouldn't require lube, usually it's the choke linkage causing that sort of symptom
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | When you say linkage do you mean carb linkage or pedal linkage? Pedal linkage may need lubed and/or return springs renewed.(carb return spring and any others). You should be able to repeat the sticking with engine off by having someone push on pedal while you watch to see if throttle returns to carb stop screw. I am guessing pedal linkage as in: Some hole is wallowed out or cotter pin is goofed up or just needs oiled. You can test your carb throttle linkage/butterfly shaft with the pedal linkage removed to see if it "snaps" back like it should. Then you will know if it's that or pedal or, as Bill says, the choke doing something.(engine off tests).
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Can't go wrong with the stronger return spring.  On my truck the black plastic gas foot pedal sticks on the tip of the metal rod linkage, in the cab, and raises the idle about 400 rpm. Is yours maybe doing the same? I have a replacement pedal a buddy gave me, just haven't installed it yet. | | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Bill - I thought probably choke also but it's good. Bart - good advice, I'll disconnect the pedal linkage and check the carb. I think it's in the carb linkage. John - I'll look at the pedal and the metal rod but I'm not thinking that's it.
I've got this on my list of things to do on Saturday. I'll let you all know. Thanks.
