1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | A few days ago I removed the hood springs in an attempt to get better fitment. While that worked well I have two resultant problems. One is that the hood latch does not work as it did and it's difficult to open. I don't see how to adjust the latch or if it even is adjustable. The bolts or screws holding it down have a strange kind of head on them...never seen such before or a tool for it.?
Second problem is that when I now use the hold up bar on the hood the other side sags a LOT and I fear it may become sprung. Maybe I should replace the hinges or the spring on that side. If I do the latter I can shorten the effective length by lengthening the lower attachment notch a bit so that the hood fitment to the cowl will remain as good as it is w/o the spring.
What say you experienced Bolters ? | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Brad. I had never seen the top two before. The springs on mine don't look anything like those coil springs though. I'll look for that tool you mentioned...I use McMaster all the time. | | |
