4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#951182 06/18/2013 4:36 PM
Trying to decide what to do with the paint on my Dad's 40 Chev. Its all original but getting oxidized and has spots where paint is even gone. Not sure if I should use some 1500 wet sand paper to smooth things and then a light buff or what to do. I know that some of the areas on the hood have a light rust forming on the spots so I have to do something with it.
Thanks Don
don stocker #951188 06/18/2013 4:49 PM
Ex Hall Monitor
Ex Hall Monitor
One of the latest trends is to scuff the paint and shoot clear over it to preserve it as is. I've not done that so this isn't necessarily a recommendation just an option. I've seen it done over light rust but my experience with paint is it doesn't stick to rust. I've not seen any of these jobs after they've aged some to see how well it holds up. If you want to keep it totally original buff off the oxidation and put a good sealer on it. Keep in mind that every time you polish you remove a bit of paint. BTW congratulations on wanting to go the preservation route. Original cars are becoming pretty scarce.
don stocker #951193 06/18/2013 5:08 PM
Thanks Tiny. My Dad passed away at the end of April and he always wanted to maintain it the best we could. It's got 30k on it and was a one owner car. I have waxed it n the past but now it needs something with a bit more abrasive to clean and smooth the finish. I have hand rubbed a few spots with diluted rubbing compound and can get some shine out of the old lacquer
paint. It's the rough spots that I'm unsure of what to do with. I know some material has to be taken off. Just not sure how to keep it at a minimum.
Don
don stocker #951341 06/19/2013 11:55 AM
I used TSRW Quick Strip on my oxidized paint.It works well,without cutting away the paint.It would be available at Marine supply stores as it's purpose is to remove scum and stuff from boats.
don stocker #951364 06/19/2013 2:13 PM
Thanks Don
Plain wax polishing does not remove paint, a cleaner will remove paint.
don stocker #951614 06/20/2013 6:32 PM
don stocker #951622 06/20/2013 7:09 PM
Ex Hall Monitor
Ex Hall Monitor
Looks really good! I love survivors.
don stocker #951647 06/20/2013 9:29 PM
Looks great Don. Do you have a 'before' picture?
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
don stocker #951763 06/21/2013 3:51 PM
Looks real nice. It's a pleasure seeing something with (enough) original paint to be saved actually get saved.
So what was the eventual process you used?
what products and grits and steps and like...the story man?
(and yeah... more pix)
Give me ambiguity
or give me something else
