0 members (),
108
8
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | I can pick up a 53 GMC really cheap because it has no compression. I have in hand, a 58/62 236 but don't know if the bell housing bolt patterns are compatible or not. Anyone know the answer? Thanks, Bob
If the dash ain't steel, it ain't real!
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Chev and GMC use the same bolt pattern.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | That was my assumption, but with differing CID, I wanted to be certain. Thanks for the reply, Bob
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | All 228, 236, 248, 256, 270, 302, should have the same bellhousing bolt patterns; some trans. bolt patterns differ. Some 270, 302 have larger flywheels, clutches.
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | Is the 58/62 a GMC 236 or a Chevy 235. I think probably a Chevy... I don't think the 236 GMC was still in production by 58.
Professional Novice
| | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | My mistake, it is a 235 not a 236. I fat fingered that one!
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | There's another discussion going on this forum now about a Chevy 216 in a GMC. Your biggest problem will be the front motor mount but many have made a plate adapter. Then modify exhaust and throttle linkage as necessary... Useful info here http://www.patricksantiquecars.com/articles.html scroll about halfway down. Wonder why the existing engine has low/no compression. It could be a big problem or maybe not so big. Good luck with it.
Professional Novice
| | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | Frank50, Buying from a friend. He purchased it after it sat for years. Pulling it home, he put it in gear and tried to start it, not putting anything in the cylinders or any other pre start work. Rings gone I suspect? Bob
