2 members (Charles in CA, Woodcmiami), 151 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#950749 06/16/2013 9:29 PM
I can pick up a 53 GMC really cheap because it has no compression. I have in hand, a 58/62 236 but don't know if the bell housing bolt patterns are compatible or not.
Anyone know the answer?
Bob
If the dash ain't steel, it ain't real!
Chev and GMC use the same bolt pattern.
My Blog
That was my assumption, but with differing CID, I wanted to be certain.
Thanks for the reply,
Bob
Crusing in the Passing Lane
All 228, 236, 248, 256, 270, 302, should have the same bellhousing bolt patterns; some trans. bolt patterns differ. Some 270, 302 have larger flywheels, clutches.
Is the 58/62 a GMC 236 or a Chevy 235. I think probably a Chevy... I don't think the 236 GMC was still in production by 58.
Professional Novice
My mistake, it is a 235 not a 236. I fat fingered that one!
There's another discussion going on this forum now about a Chevy 216 in a GMC. Your biggest problem will be the front motor mount but many have made a plate adapter. Then modify exhaust and throttle linkage as necessary...
Useful info here http://www.patricksantiquecars.com/articles.html scroll about halfway down.
Wonder why the existing engine has low/no compression. It could be a big problem or maybe not so big.
Good luck with it.
Professional Novice
Frank50,
Buying from a friend. He purchased it after it sat for years. Pulling it home, he put it in gear and tried to start it, not putting anything in the cylinders or any other pre start work. Rings gone I suspect?
Bob
