Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (TUTS 59, baldeagle, moparguy, DaveV, jmoore), 37 guests, and 0 robots.
Topics128,004
Posts1,055,246
Members48,418
#950491 06/15/2013 1:01 PM
I bought a 10 bolt GM rear end and was told it was from a second gen Camaro- it is stamped drivers side F115 also drivers side c2 passenger side 15 and the casting number is n 1249518 B I have looked at decode charts to no avail, any help would be appreciated? Thank you
jdzcn0 #950656 06/16/2013 12:32 PM
The casting number is n 1249518 B gas GM 15 on one ear then c2 on an ear and 15 on another ear and on housing itself is F115 and the axle tube has has GB G124 1 can anyone help decode, Thanks in advance
jdzcn0 #952031 06/23/2013 8:22 AM
I believe your rear end originally came from a 1975 Pontiac X body car, Ventura?
Date code: F115
F = June
11 = Day of month
5 = last digit of year, 1975
Axle ratio and Plant code: GBG1241
GB = 2.73 axle ratio
G = Chevrolet Gear and Axle plant
124 = 124th day of year
1 = day shift
3 letter (XXX) axle ratio/plant code format began in 1971, so that's why date code points to 1975 not 1965.
GB never shows up as a 2nd Gen camaro axle ratio code. It does show up on this Pontiac listing. (Look at 1975 axle ratio codes) http://ronspontiacpage.com/reference-pages/rearendcodes.htm.
Unsure whether you have a 7.5 or 8.5 in rear end. Apparently both were used depending upon the engine used.
Hope this helps, good luck on your build.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
