1 members (baldeagle), 108 guests, and 2 robots.
Topics128,037
Posts1,055,467
Members48,424
#95051 03/12/2006 2:20 AM
with headlights on if i hit a turn signal i get no brake lights. using dual filament single lights for tail, turn and brake lights. everything else works fine. any ideas on this one? will single dual filaments work for all three lights????
thanks in advance
#95052 03/12/2006 5:26 PM
Riding in the Passing Lane
Probably a bad turn switch. The brake lights go through the turn switch so it flashes the corresponding light.
1972 Chevy c10 Cheyenne Super
#95053 03/13/2006 4:53 PM
but with the headlights off everything works fine. brake and turn signals at the same time. problem only occurs if the headlights/taillights are on
#95054 03/13/2006 8:00 PM
6 heaven
6 heaven
It sounds like you have a bad ground for the rear lights.Try to supply an extra/known good ground and recheck.
#95055 03/14/2006 12:07 AM
Agree. Take a test wire & start at the socket to chassis.
#95056 03/14/2006 10:04 PM
well i think you may have been right first time wrenchbender. now i get no brakes at all. I know wiring from the firewall back is good so i started shecking under the dash. i loose power to the brakes at the steering column. so i guess turn signal switch??? power goes in from brake switch but dosent come back out. now just have to figure how to get in there... think the column is the original???
#95057 03/14/2006 11:40 PM
If it has the turn switch under the steering wheel I used to go in with a pair of needle nose pliers & bend the contact springs to make contact.
#95058 03/15/2006 4:29 AM
can i just spice in the wire from the brake switch into the turn signals behind the turn signal switch? will this cause any problems? Hope to get a new steering coulmn and rewire before too long so I would rather not fix old stuff that is on the list for replacement.
#95059 03/15/2006 4:52 PM
anybody???
#95060 03/16/2006 12:20 AM
6 heaven
6 heaven
You can't really bypass the stop light switch feed into the ts switch. the ts switch allows the brake switch as a single input and gives out 2 signals to the brake lights, when needed it will interrupt the brake light signal and allow it to be a turn signal to one side and a brake light to the other side. This may sound confusing, but this is how it works!
#95061 03/16/2006 11:09 PM
nope. sounds logical. shoulda realised that myself. Thanks texczech
