| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95051 03/12/2006 2:20 AM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | with headlights on if i hit a turn signal i get no brake lights. using dual filament single lights for tail, turn and brake lights. everything else works fine. any ideas on this one? will single dual filaments work for all three lights????
thanks in advance | | |
#95052 03/12/2006 5:26 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Probably a bad turn switch. The brake lights go through the turn switch so it flashes the corresponding light. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95053 03/13/2006 4:53 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | but with the headlights off everything works fine. brake and turn signals at the same time. problem only occurs if the headlights/taillights are on | | |
#95054 03/13/2006 8:00 PM | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | It sounds like you have a bad ground for the rear lights.Try to supply an extra/known good ground and recheck. | | |
#95055 03/14/2006 12:07 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Agree. Take a test wire & start at the socket to chassis. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95056 03/14/2006 10:04 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | well i think you may have been right first time wrenchbender. now i get no brakes at all. I know wiring from the firewall back is good so i started shecking under the dash. i loose power to the brakes at the steering column. so i guess turn signal switch??? power goes in from brake switch but dosent come back out. now just have to figure how to get in there... think the column is the original??? | | |
#95057 03/14/2006 11:40 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it has the turn switch under the steering wheel I used to go in with a pair of needle nose pliers & bend the contact springs to make contact. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95058 03/15/2006 4:29 AM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | can i just spice in the wire from the brake switch into the turn signals behind the turn signal switch? will this cause any problems? Hope to get a new steering coulmn and rewire before too long so I would rather not fix old stuff that is on the list for replacement. | | |
#95059 03/15/2006 4:52 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | | | |
#95060 03/16/2006 12:20 AM | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | You can't really bypass the stop light switch feed into the ts switch. the ts switch allows the brake switch as a single input and gives out 2 signals to the brake lights, when needed it will interrupt the brake light signal and allow it to be a turn signal to one side and a brake light to the other side. This may sound confusing, but this is how it works! | | |
#95061 03/16/2006 11:09 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | nope. sounds logical. shoulda realised that myself. Thanks texczech | | |
