0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95017 03/10/2006 8:31 PM | Joined: Mar 2005 Posts: 25 Apprentice | | Apprentice Joined: Mar 2005 Posts: 25 | I have a 1942 Chevrolet Pickup that I am going to install an EZ wiring harness in it.
There are 4 wires in the harness....Ign Power, Ign Start, Ign Coil and Ign Accessory....
The pickup has the original foot starter that has been converted to 12 volt.
How do I hook up the wires to the ignition switch and starter...
Ign Power to ignition switch Ign Coil to ignition switch...other end to coil Ign Accessory to ignition switch...
What do I do with the Ign Start wire..since this is not a key start...and how does the ign power on the ignition switch get its current?
Thanks | | |
#95018 03/10/2006 10:39 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have an ignition switch that turns to start possition you would hook the start wire to it. Just coil the wire up & tuck it behind the dash. You could cut it off or remove it from the harness but some day you may change to a diff. system. If you are going to 12 volts you will need a resistor between the switch & coil. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95019 03/10/2006 10:49 PM | Joined: Mar 2005 Posts: 25 Apprentice | | Apprentice Joined: Mar 2005 Posts: 25 | That is what I thought... on the ignition power wire that connects to the ignition switch is there any connection on the engine side that needs to be made. . I assume it gets the power from the fuse box and all the connections there. | | |
#95020 03/15/2006 12:26 AM | Joined: Mar 2005 Posts: 25 Apprentice | | Apprentice Joined: Mar 2005 Posts: 25 | Well I completed the rewiring of my 1942 1/2 ton Pickup. I used the EZ wiring harness and had to make adjustments for the foot starter and ignition switch. After I got everthing working right, I then tackled the job of installing a Signal Stat 900 turn signal kit. That was easier that I thought it was going to be. The LCD tailamps are really nice and can be seen from a distance... I did alot of research on sites like this before tackling the rewiring job but it all paid off. | | |
#95021 03/15/2006 1:23 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Congratulations, Ted!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
