1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94924 03/03/2006 8:50 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | tell me what this is all about 1962 carry allok got you so far put new battery in no start put jump pack on start went to diffrent store new bat agin starts dies put jump pack on starts runs for 10 seconds pull jump off runs 10 seconds die will do nothing with out jump pack on carge battery put in no start put pack on start run all day on pack not battery :mad: :confused:
bill
#94925 03/03/2006 8:58 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | :confused: for sure
if it runs off a "jump pack" [battery] it's a battery or cable problem re-check all your connections, sounds like the cables are not tight on the terminals or you've gotten bad batteries or hooked it up backwards
Bill | | |
#94926 03/03/2006 8:59 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Bill,
I would start with pulling the alternator and having it tested. Most of the larger chain-type auto parts stores like Checker or Autozone will check your equipment for free.
Or as Red said, double check your cables and connections. | | |
#94927 03/03/2006 9:12 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 | it dose not have a alt in it it has a 12v gen init but maybe they can test it
bill
#94928 03/03/2006 9:22 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Bill,
My bad, you're correct, Generator no Alternator. I knew that when I typed it, and did it anyways.
I still think you've probably got something out of whack with the cables or wiring(?) but I'd still have the rest of the charging system checked out.
I would think you could find a shop that can check it pretty easily. You might have to do some searching in the yellow-pages cause those pimple-faced kids in the parts-house won't know what the world you're talking about when you say generator.
Look under automotive electrical repair and I'd imagine you'll find someone in your area that works on generators.
We've got several here and they generally will also test equipment for free. | | |
#94929 03/03/2006 9:48 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | check your battery ,also you might check to make sure your fan belt is as tight as required, sometime they can be loose enough not to charge as needed, dont happen often but it can....
a volt meter will not always work when checking a battery, sometimes it will need a load put on it,, good luck ,, let us know what corrects it,, good luck,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#94930 03/03/2006 9:55 PM | Joined: Feb 2006 Posts: 70 Member | | Member Joined: Feb 2006 Posts: 70 |
bill
#94931 03/03/2006 10:05 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Bill, you've got everyone's attention now, let's see if we understand the situation, and maybe you can answer some questions that can help folks solve the running problem
1 you have a 62 burb with a 12V system and generator 2 it won't start or run 3 when you attach a battery pack, it starts and runs fine 4 when you take the pack off it stops
1 is it a 6 or V8, and is the wiring original in decent condition? does it have an ammeter or idiot light? 2 did the truck work until suddenly this problem developed, or are you trying to get it working for the first time [or after sitting a long time] and does it crank at all without the jump pack? 3 how, exactly, are you connecting the jump pack? directly to the cable ends on the battery? 4 the only reason it would die when you remove the jump pack is you have taken the battery out of the circuit, and if it won't continue to run w/ no battery, then the generator isn't generating, or the regulator is bad, but a bad generator shouldn't prevent it from starting
your turn
Bill | | |
#94932 03/03/2006 10:50 PM | Joined: Oct 2005 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 69 | I'm with Joker, Take your battery to Autozone or some were and have them do a load test. Bad battery.
New deal for old steel
#94933 03/04/2006 12:58 AM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Did you flash the regulator when you installed the new one?? Polarity may be wrong if not installed correctly.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
