6 members (ranchojuan, MikeStone1953, Biermann, Philipj, Peggy M, Wayne67vert), 71 guests, and 2 robots.
Topics128,153
Posts1,056,849
Members48,456
#948795 06/07/2013 3:33 PM
I have a 1953 truck with a 235 engine in my truck along with a 3 speed manual transmission. I've rebuilt the transmission and changed gasket, seals etc on the engine. Now I'm ready to put the oil back in.
Is it better to refill using synthetic oil in the engine and transmission?
Someone suggested synthetic oil may damage the brass found in the transmission. What about in the engine?
Ex Hall Monitor
Ex Hall Monitor
For the .02 that my opinion is worth go with the synthetic if that's what you want to use. I'm not aware of any way it can damage your engine. I've not heard of synthetic damaging transmissions either. If someone has a link to information saying that it does I'd be interested in reading it. Synthetic in transmissions info from Mobil.
The only issue with synthetic is it will degrade some older gasket materials & sealants (RTV) causing leaks.
BC
1960 C60 pasture art
Ex Hall Monitor
Ex Hall Monitor
I went to the local auto store to purchase tranny oil. I've decided to go synthetic for the engine and regular SAE 90 for the tranny.
What they had was SAE80W-90 oil. Will that do or is the 80w to thick of an oil? Specs for that tranny states it should be straight SAE 90.
I've heard of problems with our older transmissions not shifting as good with the synthetic oil in them.
From Novak Transmissions one of the premier builders of transmissions in the business.
When filling your 420 with gear oil, we recommend that you select a conventional mineral oil or a para-synthetic in lieu of a full synthetic oil. Properly assembled manual gearboxes do not have the thermal strains seen by combustion engines or hypoid gears. Synthetic fluid in these gearboxes, while not harmful, is probably an economic waste.
Hypoid gear oil is sulphurized higher than transmission oil and can be mildly corrosive to the non-ferrous alloys used for synchros, bushings and thrust washers in these transmissions.
An 80W-90, API-GL5 or MT-1 rated fluid is very good. Some claim faster shifts from using a 50W engine oil in their transmission and we do not consider this to be contradicted unless you operate your vehicle in a very warm environment.
