Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Phak1, Bucker, 1 invisible), 180 guests, and 3 robots.
Topics128,288
Posts1,058,566
Members48,492
I have a 48 half ton with bad front springs. They are flat with no spring remaining! Has anyone installed air bags in an instance like this? I could build the brackets but don't want to put these in if they will not work.
Bob
If the dash ain't steel, it ain't real!
Rather than air, you might try something like this. http://www.timbren.com/ I have a fleet of trailers that are on air. 2 years ago we specced on with composition springs along with Timbren bags to save weight. We saved about 400 lbs on the trailer and so far we are pleased with the setup.
There isn't much room to install airbags on these trucks. Especially, with the way the steering linkage is. About the only place to istall them would be on the inside of the frame.
Why not just get new springs? There are a number of different outlets for them such as; Suspension king, SD Truck springs, and Eaton Spring. Not to mention, almost all the parts houses have them too.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Springs are a much smarter way to go. By putting airbags on you're just using a Band-Aid instead of fixing the real problem.
My 46 GMC on Photobucket
what if you pull the leafs and run a bag set up kinda like a semi. two link and a panhard.
Original style springs are available from many vendors and are probably a lot cheaper than fooling around with air bags.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
