Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, Wickedbass, 55shaker), 31 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#948769 06/07/2013 1:26 PM
The light switch on my 1951 1/2 ton pickup works intermittenly. If I giggle the shaft I can get it to work. I removed the shaft and cleaned it with steel wool and added a thin coat of dielectic grease but it still will lose contact if I play with it. Do I need a new switch?
Di-electric grease decreases conductivity. It might not have caused any harm. The shaft usually turns a moving contact inside the switch - the shaft is not a conducting part, I think. Just rotating the knob/shaft might help to clean the contact surfaces of the rheostat.
Contact cleaner sprayed on the non-greased contact surfaces in the rheostat usually helps.
the shaft has nothing to do with intermittent operation, it's all in the worn contacts inside, if it's dash lights that are the problem, cleaning the wire wound rheostat on the front of the switch might help, if it's the park/head lights, get a new switch
