| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | took my 235 out today and after installing a new carb and new fuel pump i am running rich , i can tell by the smell now i have adjusted the choke and fast idle and air mixture and floats ,, what else can i do , it starts ok and runs ok only at idle it does this i can even see a tad bit of smoke ,
thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a vacuum hole in the bottom of the carb. There must be a passage in the gasket to allow vacuum to get to this hole. You say "new" carb. It probably is a rebuilt or reman. Most of the time they are not right. You need to check the float level & make sure the power valve is working correctly. Its possible it has the wrong size main jet in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | The float is fine, i dont know about the jets? I did use the base gasket with small ports that came with carb, i have 2 carbs form rock auto, they sent me 2 . I need to send 1 back after i get it running, ,,1 carb had 2 gaskets they said it was due to maybe being warped, but they are checked out on the bench, but i went with the one with 1 gasket, i guess i could get the jet from my origianal carb i changed for other reasons , so it mighthave the right jet
