| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | I have been busy installing and trying to get my dual W-1 set up running. Full throttle is great, part throttle I can deal with later, but the idle is terrible. The rear carb will not respond to mixture adjustment. I can run the screw in or out with out any effect. A slight choke will smooth out the idle. I have had the rear carb off four times and still see no problem. These are #574 Carters.
I tried to open the low speed idle jet tip a little so it would " seat ",it didn't help. I did manage to split the tip slightly but it still seated Ok, from what I can see of the wear marks on it. Send me a note if you have a old one laying around you don't need. I read this on another board, " they will not idle right with old idle jets, but you can make them work by opening the flare back out"
Where to next? Pull off both carbs and compare parts and clean the rear one again. I bead blasted them last time with real fine glass beads, then soaked them in carb cleaner, followed with high pressure air. They sure looked cleaned.
Joe | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I don't know what I am talking about, but what happens when you switch them? As a troubleshooter, this is what you do.. then it provides clues on the problem. You cant just assume the problem would be switched.  | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Do you have the correct gauge for setting the metering rod?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may need to raise the float level a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Did not try and switch them, I removed the whole setup and went back to the single carb till after the weekend show ii am going to. I hate going places when its not running 100%.
The metering rod adjustment is for the mid range, don't think it effects idle, but then I am not 100% sure of that. I do not have a gauge, but I did set both the same using a dial indicator. I figure I can tune mid range and fuel economy by adjusting the hight of the rod.
For now I am looking for circuit diagrams to see how the idle circuit gets its fuel and how it gets to the engine.
I am open to any idea's on what to look for. I have been working on these for a year off and on, cleaning, building, setting linkage, making a filters, etc... I was hoping I them right.
Joe | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you probably got blasting media stuck somewhere you don't want it. There are too many small passages in a carburetor to be sandblasting. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I have a W1 in the garage with a split low speed jet and I can tell you it will not run right. What I did is buy a "parts" W1 and used the jet from there into my rebuild.Carb King has new jets you can call Him.
Pete
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | Pete, thats my next move. I am on the look out for one now.
When I bead blasted them, my media was almost powder since its pretty old. Even new glass beads are very small. I used shop air, 150 psi to blow them out. I don't believe its plugged with media, rust maybe as these were really dirty cores when I got them.
Joe | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Joe - in the for what its worth category:
I learned (the hard way, naturally) that glass beads accumulate static electricity, especially with cast iron castings, and CANNOT be completely cleared with air pressure. I learned to ALWAYS wash the castings with pressurized water through all passages on cast iron castings. The older the beads, the more static electricity.
Once I acquired the ultrasonic cleaner, 30 minutes in it following glass beading would suffice. I no longer had to blow pressurized water through the passages.
And I am assuming you have already checked that the throttle positioner screw on the carb that does adjust is not in so far as to prevent adjustment on the carb that will not adjust.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I've always wondered about using alumabrite, I know it takes rust off too.... | | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | No glass beads left, I gave it a really good wash down and more air cleaning today. I believe I found the problem. I installed bronze bushings in the throttle shafts bores on both carbs. The rear carb that was acting up didn't have all the bushings in one side. The short side only took one bushing, the long side takes about one and half of the size I have. I must have got busy and forgot the 1/2 piece. This leaves a pretty big vacuum leak around the shaft and the throttle blade. Today I pressed in more bushing till it was sticking out into the throttle bore. I carefully filed it down to match the inside diameter and radius of the bore. I believe it will respond much better to tuning now. I also solder up the small crack in the low speed jet were I broke it. The soft solder formed a good seal so I hope that is taken care of.
Next week I will reinstall the set up and see how it runs. The little I drove it, it responded pretty good, even with fuel from last November! It was almost empty so my short drive was to the gas station.
Joe | | |
