7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
Mod | | | Forums66 Topics128,136 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Here is a site on using Rust=Oleum paint for painting a car.... I think I'll follow it a long and see what it is. Claims he isn't doing the old roller paint job like other have..... www.rustoleumpaintjob.com John | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I painted my frame with RO. The paint is not as hard as the urethanes. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Has anyone downloaded that? Every time I see "FREE" stuff I'm very leary. 99.9% of the time it's just bait to get you to their site then after an hours worth of sales pitch they hit you with the $39.95 cost for the complete detailed instructions. It gives you the idea that it's sponsored by Rustoleum, I'll bet it's not.
Rustoleum doesn't hold up as well as automotive paint. I've painted trailers, and lawn tractors with it and after a few years it's all chalked up and dull. Also GW is right about the hardness, the binders in Rustoleum arent as good as in the auto paint.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Thanks for the intel on this. I won't bother now looking for some 7272 to check color correctness. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You are probably correct there Denny, not much given away for free anymore. Usually just enough info to try and get you to part with some money for the full information. Going to take me a while to download this with dial up anyway....
John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Rust-Oleum, 7272, which color is that??? Most of what I use is the Satin Black for things. They claim it is pretty close in color to the black GM used on things such as air cleaners ect.... | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | It is supposedly a close interior color for 53 trucks 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Only 37 dollars to find out the information.... From what I read it sounds like to give the paint more lastability, he is clearcoating the finish. Something I had thought about myself before. John | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Rustoleum doesn't hold up as well as automotive paint. I've painted trailers, and lawn tractors with it and after a few years it's all chalked up and dull. Also GW is right about the hardness, the binders in Rustoleum arent as good as in the auto paint.
Denny G I completely agree with the above statement. Consequently, I avoid using Rustoleum where the paint is constantly exposed to sunlight. But, I use Rustoleum for underhood parts, frame, inner fenders, etc. Basically, anywhere the sun doesn't shine. It will perform very well. I also used Rustoleum for the steering wheel, and mast jacket, but I cleared the paint for hopefully improved durability. The clear did not lift the Rustoleum, but I allowed the paint to cure for a least a week or more before applying the catalyzed automotive clear. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I second the rustoleum. Mines holding up well after a year or so. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Rust-Oleum, 7272, which color is that???.. ...7272...Click... It's rattle can for garage builds and po folks ...click... | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | David,
What type of clear did you use over the Rustoleum? Automotive or??
thanks John | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | DADS50, Looks good to me. I use Rustoleum for a lot of paint projects. About the only thing I don't care for is the Rustolem rusty metal primer in the spray cans. Handy stuff for quick top coating, but not very rust resistant. If it is outdoor, I like to use the Rustoleum primer in the quarts and spray it with a gun, it still seems to be enamel. Sometimes if I have rusty metal I'll mix in a little Penatrol with it..... I take this is the color you use for cab interiors?? is it a satin color?
John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks,
I would call it a satin, there is no gloss to it. I don't think I would want a shiny dash. I did not clear it and it held up so far for two years.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Your right there, you'd not want gloss paint anyway. you don't get any "rub" off of the paint do you? I know the silver is bad about that, even when dry, it rubs off on your fingers ect... over time. How many spraycans does it take for a regular AD cab?? John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Have not experienced any rub off, I don't put any wax on it, just clean it with Windex and rag.
I don't remember how may cans it took. 6 to 8 cans should cover it. I purchased a case from Grainger and had some left over. I was covering a blue.
The rattle cans are more expensive now than they were three years ago. If you have the means and ability it may be cheaper to spray using the interior colors offered by the vendors.
If you don't have a spray system then maybe the rattle cans may be an option. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | David,
thanks John John: As I mentioned in my previous post, I used catalyzed automotive clear coat. Using Rustoleaum clear would not help the durability of the color coat in my opinion as both would be air cured enamel. Also, I only used the Rustoleum on the steering wheel and mast jacket as I could not find a color code in order to purchase single stage automotive paint. Nor did I want to spend $65 when I only need such a small of amount of paint. The Rustoleum equivalent of the original color for the mast jacket was close enough for me and very few would ever know the difference. Here is a poor photo of the restored mast jacket using Rustoleum and automotive clear coat.
| | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | DADS50 did you use Rustoleum primer before spraying your interior with the 7272?
I like the look of that, I'm going to try it. Thanks for putting pictures up of your finished product! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I did use a primer I just don't recall what brand ...pic... I put the brown on some of areas that didn't need it due to being covered by floor Matt or firewall cover. Thanks | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Cool thanks! I'll put up pics of mine as soon as I get it sprayed.
| | | | | Joined: Feb 2013 Posts: 1 New Guy | | New Guy Joined: Feb 2013 Posts: 1 | | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I haven't been able to find any 7272 yet...... may have been discontinued. John | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Try searching 7272-830 Dark Bronze Metallic
It's on amazon and do it best web sites I could not find it on the shelf and ordered some from grainger
Good luck | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Hey guys, I wanted to chime in and let you guys know I've found an alternative to Rustoleum #7272. It's a Rustoleum product that is the EXACT same color (I've checked) and it's a completely different number. Here it is on their website: http://www.rustoleum.com/CBGProduct.asp?pid=32&sid=7713830 When I went to Home Depot this weekend I was searching for more 7272 and they just don't have it. I found this 7713 and bought 6 cans and did the interior on my truck and it matches the doors I did with 7272 perfectly. Amazon keeps running out of the 7272, probably because so many guy on there are ordering it! lol. Anyways, this 7713 seems to be a good replacement, AND Home Depot has it in stock!. I used their "Professional" series primer underneath it and everything seems to be good. I've scratched up a couple of places on the paint during reassembly and just spray over them and it melds together nicely. I hope this helps the guys that are going this route, I've found it an easy process that dries quickly. No it's not perfectly smooth like a 'gun' would give you, but I like the flexibility of the 'rattle can'. Here's what I've got so far: http://www.flickr.com/photos/ajporsche/8861252872/in/set-72157632234070092~Dave | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Sorry to hijack thread...where did you purchase the speaker grill and glove box door? Are you happy with the quality? | | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Hey David, I'm pretty sure I ordered them from this outfit: http://www.classicpartsusa.com/category/1950_Truck_Parts_Dash_Parts Yes, I'm very happy with the quality. I got the stuff I ordered from them reasonably quick, but I do remember having some communication problems with them regarding a backorder of some other items. Overall I think the site is ok, but there's other places online that 'feel' more organized. Their prices are pretty good though. ~Dave | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Sears had the 7272 April, 2013. I had to order it but they delivered to the door.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2012 Posts: 72 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 72 | Good to know Mike, thanks.
Nice truck by the way!
~Dave | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I have not heard of this vender. I would have to compare their prices with the other guys who have been around awhile first. If the difference was minimal, I would probably stay with the tried and true. Just my opinion. Steve | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | I've been following this thread and decided to chime in. Painted a 65 f^^d for a customer last year with Valspar equipment paint in MF gray. he was looking for a "inexpensive " job and wanted it to look military-ish. well after a year of use and sitting outside in Wisconsin it looks like the day I painted it, with some rust bubbles notwithstanding.(the prep consisted of 2 pads of 60 grit on a DA sander). also painted 3 50's era Harleys in the same paint to match the truck. he used the combo to sell the harleys'. sold all three and have more to do this summer. long story short - I would not recommend equipment paint unless you know the results you are looking for. especially on a frame off. a quick paint over, maybe. btw I used it though a HVLP gun with thinner and a hardener. 2coats over equip primer. there-my 2 cents
daren | | |
