3 members (Sjm, Forty9, 1 invisible),
90
Mod | | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Looking for some advice a good 283 pistons .I am using the stock crank 010-010. 030 over borewith Eagle i beam rods and 305 heads ,voodoo cam ,headers ,and 600 cfm holly.Not going to be a race truck just a crusier.The only thing I see out there are sealed power pistons or KB Hypereutectic pistons.Does anyone have any advice on what to use? Thanks | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For just cruising you have a bad case of overkill but for sure it should be bullet proof. If your voodoo cam is a hydraulic one then either of those pistons should work since the lifters will limit the rpm long before one of those Eagles can yank a wristpin out of a piston. Seriously, if turning 5500 or less they will do the job and we have turned the KB's way above that on claimer circle track engines. 283's with their 3 inch stroke are much easier on pistons (at the same rpm) than their longer stroke cousins.
Evan
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Had KB's in my Corvette 350 build and busted 2 of them in less than 2k miles. Big discussion of what all may have gone wrong but heard there were some issues with the KB's so I went back with forged pistons--5k later no issues. My 2 cents..... | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I'm putting a .03 over 283 together with the sealed power pistons, I hope they hold in there. Its not for performance just a nice driver.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
