6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#947273 06/01/2013 2:16 PM
Looking for some advice a good 283 pistons .I am using the stock crank 010-010. 030 over borewith Eagle i beam rods and 305 heads ,voodoo cam ,headers ,and 600 cfm holly.Not going to be a race truck just a crusier.The only thing I see out there are sealed power pistons or KB Hypereutectic pistons.Does anyone have any advice on what to use?
Longhorn #947413 06/02/2013 7:42 AM
For just cruising you have a bad case of overkill but for sure it should be bullet proof. If your voodoo cam is a hydraulic one then either of those pistons should work since the lifters will limit the rpm long before one of those Eagles can yank a wristpin out of a piston. Seriously, if turning 5500 or less they will do the job and we have turned the KB's way above that on claimer circle track engines. 283's with their 3 inch stroke are much easier on pistons (at the same rpm) than their longer stroke cousins.
Evan
Longhorn #947596 06/02/2013 10:45 PM
V
V Offline
Had KB's in my Corvette 350 build and busted 2 of them in less than 2k miles. Big discussion of what all may have gone wrong but heard there were some issues with the KB's so I went back with forged pistons--5k later no issues. My 2 cents.....
Longhorn #947634 06/03/2013 5:46 AM
I'm putting a .03 over 283 together with the sealed power pistons, I hope they hold in there. Its not for performance just a nice driver.
