6 members (Millenimech, mason86, delky, UtahYork, Otto Skorzeny, 1 invisible), 65 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#94750 02/22/2006 1:38 AM
Junior Member
Junior Member
Hello to all,
This 65 electrical problems are driving me crazy! First posted 'dead truck' and replaced battery, alternator, voltage reg, and brand new alt. wiring harness, along with instrument cluster harness. Now i have no tail lights and only a faint rt signal and no lt signal. Replaced the tail light harness and still no luck. What the hell?
Patrick
#94751 02/22/2006 1:43 AM
Sounds like a "grounding" issue.
#94752 02/22/2006 1:44 AM
check/redo all the grounds, especially at the back - make sure the tail light pots and bed have GOOD grounds and see what happens
#94753 02/22/2006 3:05 AM
Z
Z Offline
check where it plugs in at the firewall.
#94754 02/22/2006 9:03 AM
And it wouldn't hurt to be sure the bed is solidly grounded to the frame. I seriously wire brushed a spot on the frame and on the bed of my truck and put a battery ground strap there,then sprayed it with battery terminal protector.
A good ground on your taillight pots won't help if the bed isn't grounded. Like Bill has said,most taillight,turn signal and stoplight problems can be traced to a bad ground somewhere.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
