| | | Forums66 Topics128,151 Posts1,057,003 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Greetings from New Jersey, Photo of Chevy 6 cylinder Distributor Shaft with the Drive Gear still installed. How do you remove this gear without destroying the gear or the shaft ? What's the technique for peening over the Lock Pin for re-installation ? I've never done this before. See photo below: http://i669.photobucket.com/albums/vv57/glp0329/DistributorGear_zpsd9ce75f0.jpgThank You, George
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You will need to grind off the headed end of the pin to drive it out. I always use a roll pin as a replacement. I have NOS pins but I split a gear trying to use them.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | When I rebuilt my distributor I filed the peened area of the lock pin down and drove it out. I used a correctly sized split roll pin to replace the lock pin and have had no issues. I believe I had to cut the split pin to get the proper length...been a while!
Ed
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Dave, I just got ( 9 ) lock pins GM NOS - GM part # 865180. If these are not the best choice to use for re-installation. Please tell me the source & part # for the roll pins you use. Obviously these roll pins need to be peened over.
How is this done ?
Please explain the technique.
Thank You, George | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The "pin" is soft. I used a file to make it flush with the gear. Put a small punch just smaller than the pin on it. Supported with my vice and some rags and drove it out with a hammer. Replaced with a roll pin from the auto parts house. Came in a box with about a dozen different sizes. Just picked the best fit and pressed it in there. Mine was a bit long so used the angle grinder to get it close to the gear. Some room in there so no need to make it perfect. Was not to tough and worked just fine. Was the only way to get the shaft out of the housing any way. Roll pin does not need to be "peened" over. Spring tension will hold them in place.
Steve H
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | That is what I was talking about. Thanks Pre'68 Dave
Steve H
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Obviously these roll pins need to be peened over.
How is this done ?
Thank You, George Roll pins are NOT peened , they are a spring and friction holds them in the hole. You just need to pick the right (tight) diameter. Regards Dusty | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Ok...I get it now. Use a roll pin that
fits tight & tap it home & trim to length.
I sure hope the spring pressure holds this
gear on .....I'd hate to have this gear come
loose & lose the small fortune that I have
invested in this engine rebuild.
From the given advice...some of you have actually
done this without a problem. Is that the fact ???
I don't like to assume anything.
I'm learning alot rebuilding this 1954
235 engine.
Many of the processes, I've never come upon
before.
Thank You everyone for the advice.
George | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have used the roll pin method many times.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Also, think about where this roll pin is sitting. It CANT come out. I suppose you could spot weld the roll pin into place, but I don't know what metals are used. Probably not the best idea. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A lot of distributors have roll pins in them originally.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 |
