7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#94741 02/21/2006 3:34 AM | Joined: Nov 2005 Posts: 248 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 248 | I bought a new internally regulated alternator for the 230ci engine I'm getting ready to put in my '63 Fleetside and when I put it on the stock mounting bracket it doesn't line up with the balancer and water pump. Engine Pic Any suggestions? Can I get another pully? | | |
#94742 02/21/2006 4:01 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | you need the later bracket that bolts to the block, not sure but I think 68-72 will work. brian | | |
#94743 02/21/2006 3:11 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I had a like problem, I had to go back the next day and get my pulley off the old alt,,, that did it..Fred
sorry I did not read close enough, thought you were replacing previous alt,,, as stated, you will probably need new brackets... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#94744 02/21/2006 3:43 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i had to make a bracket to offset the new 10SI alt on my bolt. the bracket moves the stock alt bracket forward by (x) . It's 1/2'' thick, 1-1/2''x 5'', two through holes and two threaded holes. although I'm running a 292 it's all the same
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#94745 02/21/2006 4:22 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | My alternator has a dual pulley, only the furthest one out is being used the inner one is open. | | |
