4 members (78buckshot, D B Cooper, Otto Skorzeny, Ponchogl), 148 guests, and 1 robot.
Topics128,089
Posts1,056,144
Members48,436
#946950 05/31/2013 1:07 AM
I finally replaced my rear crankseal off my 235. Would it be wise to put a bit of silicone at each end of the lower bearing cap where the rope ends? If yes what type of product would you recommend?
Dan
Never silicone, to use that everything has to be super clean.
Some aviation permatex or a dab of #2.
thanks I went out and bought some permatex aviation today, I don't want to do this job twice
It won't go to waste, use it on such things as fender bolts, door hinge bolts and any place that the bolts are exposed to water. It will keep the rust away from the threads. A tube of #2 would be nice too, its thicker and is good for areas like where the oil pan side gaskets meet the end gaskets. I have never had anything with #2 on it leak, oil or water.
Make sure that you don't get any on the crankshaft to seal wear area, well a pin point size shouldn't hurt a thing, but try to avoid it.
I tried to find this tube #2, who makes it Permatex?
My Blog
