| | | Forums66 Topics128,086 Posts1,056,097 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I finally replaced my rear crankseal off my 235. Would it be wise to put a bit of silicone at each end of the lower bearing cap where the rope ends? If yes what type of product would you recommend? Dan | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Never silicone, to use that everything has to be super clean. Some aviation permatex or a dab of #2.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | thanks I went out and bought some permatex aviation today, I don't want to do this job twice | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | It won't go to waste, use it on such things as fender bolts, door hinge bolts and any place that the bolts are exposed to water. It will keep the rust away from the threads. A tube of #2 would be nice too, its thicker and is good for areas like where the oil pan side gaskets meet the end gaskets. I have never had anything with #2 on it leak, oil or water. Make sure that you don't get any on the crankshaft to seal wear area, well a pin point size shouldn't hurt a thing, but try to avoid it.
| | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I tried to find this tube #2, who makes it Permatex?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | |
