1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Have a fresh rebuilt 61-261 sitting on a cradle ready to be fired up. Need some wiring direction. The coil is 12v with internal resistor and 2 terminals on top marked + and --. The starter is a 12v solenoid type with 2 terminals marked R and S. The distributor has one terminal on the side below the cap. The remote pushbutton starter has 2 wires with alligator clips on each end. And of course the battery is sitting on the floor. Where do all the wires go to make this hummer hum? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | coil + to batt + [via toggle switch or a clip for easy quick removal] coil - to that single wire on side of distributor one push button clip to batt + other push button clip to starter S
and if it's a fresh rebuild, fire shouldn't be applied until you're ready to run it at moderate RPM for 20 minutes for break-in
Bill | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, also use a drill w/ broken screwdriver..remove the dist and get your oil pressure up first. The minus side of the coil is the tachometer connection as well in case you want to monitor your rpm. I would be concerned with two things on a 261.. the oil pressure and making sure oil is getting properly up to the rockers, and water temperature since you want to ensure the steam holes properly lined up. Good luck! I just did this very same thing last week!
