1 members (Bill Hanlon),
138
Mod | | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | I have a 55 (2nd) Suburban and would like to install bucket seats in the 2nd row and a bench for the 3rd row seat. Not using original style seats, they are from a newer suburban, or mini van. My question is, can they be mounted to the wood floor? Would put some plating under the wood floor for support.
I would also like to install carpeting over the wood floor with some dynomat over the wood.
Any advise or recommendations would be appreciated.
Thanks | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I know this has been done, sorry no pictures. If I remember right, they cut out the floor brackets from the donor truck and attached them to the wood floor using reinforcements underneath the wood. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | late model stuff is a lot cheaper than re-doing original seats. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | late model stuff is a lot cheaper than re-doing original seats. And probably more comfortable too. You can get bucket seats with the integrated seat belts that will make the install easier and safer. Not all suburbans have to look alike, it's the differences that make them popular. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Am not trying to be a smart/azz but how many times do you expect to have seven people (6 passengers) in your Burb on a trip long enough to require such comfort? | | | | | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | I have 6 grand kids that love this burb and will be going on runs with me. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | We suburban owners are a breed of our own. It doesn't matter how many people are in the truck at one time, we want to have all of the seating available all of the time. Integrated third row seat 2000 - 05 Suburban Yukon XL Leather Third 3RD Row Seat OEM Integrated bucket seats 1999 - 2006-Chevy-Tahoe-Silverado-Suburban-Power-BUCKET-SEATS I like these because it looks like you can remove the headrests when not in use for better visibility. I do not know the width of these or if they will fit without alterations, but I have seen them used before. anchor bolts Thanks, MNSMITH for hosting the pictures!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for the photos, George
I am installing seat belts in my original-seat Suburban. But, long trips on those seats is a pain in the . . .
If I was going to change the seats for kids, those integrated seats seem to be a a very comfortable and safe set-up.
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | when i put the 3rd row seat in my 65 i cut the mounting pockets out of the 99 suburban and mounted them in the floor. that way it is easy to remove the seat if you want to for storage | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | George,
What year did those come out of? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | when i put the 3rd row seat in my 65 i cut the mounting pockets out of the 99 suburban and mounted them in the floor. that way it is easy to remove the seat if you want to for storage Pictures would help. I know this can be done, I couldn't find clear enough pictures to show it. I changed the information on the seats to show what they are from. If someone could host these pictures they will be saved for future reference ...........g | | | | | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | lEONARD, Do you have any pictures of your install?
GMONIZ, Those are the seats I've been looking at. Already installed the front seats from a mid 90's Extended cab. They lean forward and then slide for easy access to the back.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Those seats look great. Hopefully Leonard can post some pictures of his install. I would like to have comfortable seats that are easy to install/remove.
Right now I'm sitting hear trying to figure out how to put some scrap pallets in the back of my burb. Would be much easier to do if I could just "unsnap" the seats and remove them. Having to crawl around and unscrew the wing nuts and then not lose them is a pain.
I want to be able to pile the family (5 of us) in the burb when I need to, but I still want to be able to quickly pull the seats when cargo carrying is necessary. Call me greedy!!
Larry
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i no longer have the suburban what i did was cut the mounting brackets out of the floor of a 99 suburban about 4 "extra. then cut a slot in the floor of my 65 . then made a plate to go under the floor and mounted them with carraige bolts i used the third seat from the 99 sububan. so the third seat mounts just like it did in the 99 suburban | | | | | Joined: Oct 2020 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2020 Posts: 25 | If you changed out your middle and rear suburban seats, how about you be a good chap and sell me your old ones? Ill pay a fair price and shipping.
Mark | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Mark, buying and selling in the Garage Forums is prohibited by Stovebolt.com rules. Please conduct business by PM or email. Many members list their email address in their profile.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark I informed you and hour ago that buying and selling should not be done in this forum.
"Regarding: "Can you and will you make a middle and rear seat for someone?"
Please continue this discussion in Private Messages and/or email.
You might not be able to use Private Message until you have made around five posts (about your trucks - or truck-related questions)." | | |
