3 members (Guitplayer, Patina 54, Steelonsteel), 42 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#946636 05/29/2013 3:49 PM
7
7 Offline
Re-installing the Pitman Arm on a 51 Chevy 3100 and I am just wondering how far it should tighten onto to the splined shaft. Right now I show about 1/4 inch of shaft behind the arm and its about as tight as I can get it without installing the steering arm. Just thought I would make sure it's seated properly before installing the rest of the steering gear. Before re-installing the arm I thouroughly cleaned the shaft and treated it with a light coat of anti-seize.
Riding in the Passing Lane
Sounds about right. There will be about 4-6 threads showing after the lock washer & nut are tightened down.
1972 Chevy c10 Cheyenne Super
7
7 Offline
Thanks! I will re-assemble the rest and torque it down.
