5 members (GMCJammer51, DuckRancher, Peggy M, 49nut, 1 invisible), 118 guests, and 1 robot.
Topics128,110
Posts1,056,245
Members48,437
#9465 07/01/2002 4:44 AM
Just a few steps from the crusher at my local wrecking yard, a gmc 2-ton 1950 is perched atop two other cars. I took the brake booster, but also saw the Oil fill tube with a breather filter attachment for use in a pcv system. Will this tube fit a Chevrolet 216/235 ? What else should I look for?
Most all the big truck GMC's have PVC's on them. don't know if they will work on Chev's or not. Most had valve in valve cover which was dented in or cut-down to clear hood or things? Some years of COE's in Chevy have this system or on Delivery's that had just chassis and front fenders when built, forward control they were called!
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
Anonymous
Unregistered
Anonymous
Unregistered
Section 0 sheet 4.00 of the '47-551st series Chevy truck assembly manual shows in detail the parts to the PCV system. grin
#9468 07/02/2002 12:56 PM
I was going to try to use the gmc oil fill/breather tube assembly. Will it fit the Chevrolet block?
