| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Just a few steps from the crusher at my local wrecking yard, a gmc 2-ton 1950 is perched atop two other cars. I took the brake booster, but also saw the Oil fill tube with a breather filter attachment for use in a pcv system. Will this tube fit a Chevrolet 216/235 ? What else should I look for? | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Most all the big truck GMC's have PVC's on them. don't know if they will work on Chev's or not. Most had valve in valve cover which was dented in or cut-down to clear hood or things? Some years of COE's in Chevy have this system or on Delivery's that had just chassis and front fenders when built, forward control they were called!
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Section 0 sheet 4.00 of the '47-551st series Chevy truck assembly manual shows in detail the parts to the PCV system.  | | |
#9468 07/02/2002 12:56 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I was going to try to use the gmc oil fill/breather tube assembly. Will it fit the Chevrolet block? | | |
