0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Just want to know before I go this way...it is an expensive mod.
Yes, my 4 speed has the granny first...basically too low to use. If I go to a 3.38 or so in the diff, will the tranny gears be at proper ratios for good driving at both low and higher speeds ?... What gear ratio diff would be best ? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It will improve in all the gears as long as your engine is running good. The specialty gears for that model are 3.55. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Yeah, I guess I knew it would improve all gears but just wondered if the resultant trans gear ratios will be good/correct for the rpm's ....likely a silly question...again...;) | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dogface,
If you want to know about change to ring & pinion gears in a 47-54 3100 torque-tube rear-end, the only conversion that is available is a 3.55 R&P set.
I have that conversion in my Suburban, with an SM420 4-speed. First gear is still too low, except when I need it with a full load (a full set of 7 passengers).
The big advantage of this setup is the the ~15% decrease in RPM in high gear. Also, if you install the bearing/bushing installation kit, you will most likely experience a much quieter cab.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Tim mentions many great points. I too have the 3:55 gears and with the overhaul kit makes for a completely different truck. Much quieter.
Depending on where you live, if you have hilly roads or larger and an original 216 it can make it under powered on longer grades.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dogface,
Will you be running an original 216?
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | No...my 235 from a 56 ....but you knew that since I just bought that intake set up from you  | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you want to know about change to ring & pinion gears in a 47-54 3100 torque-tube rear-end, the only conversion that is available is a 3.55 R&P set. The standard ratio for a 1954 was 3.9 and will fit right in. It is not a huge improvement over the 4.11 but can be a little help.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dogface,
Yep, I knew what engine you have - a 216 was commented-on, so I thought you should let folks know. I am looking forward to seeing your driving report.
Sorry, I did not mention that 4.11 to 3.9 option (of course, Dave is correct - thanks for the correction).
That ~9% gain from going from 4.11 to 3.9 is about what I got going from 3.9 to 4.11 (my only option). I gained about the same % by switching to 16" high profile radial tires.
You'd need the 1954 3.90's ring-gear carrier. I'll give you a 3.90 R&P and carrier for the cost of shipping, but I'd recommend going all the way to 3.55.
| | | | | Joined: Nov 2012 Posts: 543 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 543 | Thanks Tim, but I'd go to the better option. It won't be all that soon. I have spent a lot in a short time so far. My truck is ok for now ...even on the Hiway but won't do much on the interstate where I'd get blown away....it's a real free for all on I-80. | | |
