4 members (Guitplayer, 50Chevy3100, Otto Skorzeny, Hotrod Lincoln), 162 guests, and 0 robots.
Topics128,106
Posts1,056,211
Members48,436
#946566 05/29/2013 10:07 AM
New to the forum. Just picked up an 1949 4100 1 and 1/2 ton short bed grain truck and need to work on brakes right away. The truck has duel wheels. Can anybody help with a source for brake shoes, wheel and master cyclinders?
Big "B" #946603 05/29/2013 12:56 PM
Welcome aboard. Napa is a good place to start, find a counter guy that goes for the paper books.
I have had the best luck with commercial brake supply outlets. Find one in your area they will be able to reline your shoes. It is best to pull the drum and hub then remove the backing plate as an assembly. Take that assembly and drum to your bake parts supplier so everything can be identified.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Big "B" #946638 05/29/2013 3:51 PM
Thanks for the advice. I tried NAPA over the phone but my guess was the guy just checked the computer inventory. I will try again and make sure they check the book next time.
Big "B" #947087 05/31/2013 5:38 PM
If the whole backing plate comes off couldn't you replace that with a disc setup from a different truck or am I just wishing it worked that way.
Big "B" #947167 06/01/2013 12:00 AM
Also Aleretta truck parts they are great and helped me with all my brake questions.
Big "B" #947194 06/01/2013 4:42 AM
That's Alretta Truck Parts in Framingham, Ma. (508)788-9409. Ask for Geoff.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Big "B" #947745 06/03/2013 6:41 PM
24601
BigB Send me a PM -- I might have a set of wheel cylinders (NIB) to fit your truck. I got them for my '49 ton and a half and then switched to a different axle. If yours has it's original single speed axle, we might be in business.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
How do I send a PM
Big "B" #949700 06/11/2013 7:18 PM
Red dot, center of chest ...
Originally Posted by Big"B"
How do I send a PM
You can't until you're out of moderation. Once you've posted four times, you'll be able to PM.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Big "B" #949805 06/12/2013 9:14 AM
I think I really got lucky. The husband of a gal I work with is a retired truck mechanic and they just moved close to my farm. The guy is in to old grain trucks as well. Looks like I may have a good resource to help with my '49 4100 1.5ton restoration.
I will PM you as soon as I am out of moderation.
Big "B" #949842 06/12/2013 11:57 AM
you can get your wheel cylinders and master cylinder re sleeved here http://brakeplace.com/ fair price and quick turn arounds. ive used them a couple of times, if you call ask for rob. any big truck shop that does cluth and brake relining in your area can perform these services.
Big "B" #949953 06/12/2013 6:06 PM
I'd definitely check with Geoff, at Alretta Truck Parts. Several of us here have used him for our Vintage Bolt brake needs , & he's had everything readily available. Even knows the part numbers by heart. They specialize in truck brake parts.
Spanky Hardy
1950 GMC 250 1-Ton
Thanks for the tip on Alretta Truck Parts in Framingham, Ma. (508)788-9409. My Mechanic was able to find front wheel cylinders for my 49 1.5 ton Chevey 4100, but could not find rear wheel cylinders. He suggested re-sleving both existing ones for $400.00. I contacted Alretta and spoke with Geoff. He new exactly what I needed (I hope) and got them in the mail that day for $81.00 each. I guess we will see if they are the correct ones soon.
