1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 17 New Guy | | New Guy Joined: May 2013 Posts: 17 | Should I put throw out bearing on trans shift and then mate to clutch? Which end goes towards clutch? Does throw out bearing go inside of plates or remain outside? Do I need clips to secure fork to throw out bearing? Someone else disassembled so I having trouble with the assembly process. Any references? Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | In general terms the clutch and pressure plate are centered with a guide and bolted to the flywheel, than the throw out bearing with the longer depth closest to the pressure plate springs slips onto the trans input shaft then engage the trans. The clutch fork usually just slips onto the throw out bearing without clips. But we need to know what truck/engine you are referring to be specific.
Drew
| | | | | Joined: May 2013 Posts: 17 New Guy | | New Guy Joined: May 2013 Posts: 17 | Clutch and flywheel/bellhousing is a 50 chevy wagon with a stock 235 engine. Flywheel, clutch and pressure plate already mated so I only need to input transmission shaft with throw out bearing and fork to complete assembly. Looks like your info should help me complete. As you probably noticed, I am new to the forum and fifnd it very helpful. | | | | | Joined: May 2013 Posts: 17 New Guy | | New Guy Joined: May 2013 Posts: 17 | Ready to install but I think I need a fork ball seat retainer to hold the fork to the ball in place. any suggestions as to who has part? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you need that part like TC showed, I can mail you one. Chevy dealer might have it. It was used on the bigger trucks for a long time. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
