6 members (Jon G, baldeagle, RLB, frogfarmer, ndkid275, Hush), 74 guests, and 2 robots.
Topics128,087
Posts1,055,974
Members48,430
#945926 05/26/2013 2:05 PM
Hello all, Got a question about grille supports. Are the grille supports all interchangeable from 60-66 models? I just bought one for my 61 from a later year thinking they are the same, but then saw them listed somewhere as being different. I haven't received it yet, so I can't compare it to mine. I would appreciate any answers on this, thanks, apache c-10.
I believe the only difference is the location of the holes for the grille.
Check out this attachment. It follows my logic since there are the same number of different grille supports as there are different grilles.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=19
Hope that helps!
Apache c-10 #946026 05/26/2013 11:54 PM
Hello, Thanks John, that makes sense. If its just the holes for the grille that should be no problem, I can always drill some holes if necessary. I was just hoping I didn't buy something I wouldn't be able to use. Thanks, Ken.
