| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello all, Got a question about grille supports. Are the grille supports all interchangeable from 60-66 models? I just bought one for my 61 from a later year thinking they are the same, but then saw them listed somewhere as being different. I haven't received it yet, so I can't compare it to mine. I would appreciate any answers on this, thanks, apache c-10. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I believe the only difference is the location of the holes for the grille. Check out this attachment. It follows my logic since there are the same number of different grille supports as there are different grilles. http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=19Hope that helps! John | | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello, Thanks John, that makes sense. If its just the holes for the grille that should be no problem, I can always drill some holes if necessary. I was just hoping I didn't buy something I wouldn't be able to use. Thanks, Ken. | | |
