1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | I'm in the middle of changing the rear rope crank seal of my 235. The lower rear bearing cap came off without problems. However, the upper rope seal is a different story. It was cut flush with the block and I have no seal to grab on to so that I can try to pull it out. I tried pushing it from one end with a flat punch but it did not slide at all in the groove. I thought putting the new one on would be a challenge, it appears I've got my hands full with taking this one it out. Anyone with ideas/suggestions? I have loosen the other crank bearing caps and the crank drop roughly 1/8". Dan | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I usually loosen the rod nuts, unbolt the transmission and slide it back enough to allow the trans front bearing retainer to clear the bellhousing pilot hole. This lets the crank drop enough to work on the seal.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Getting the old one out can be quite a job. The kit has a screw with a handle on it. You thread it into the end of the seal and pull. A wood screw, about number 8 would probably do the trick. I used a broken coping saw blade to stick up between the block and the seal to try and break it loose.
For installing the new one I used picture hanging wire tied to the end of the seal. I use a screwdriver to guide the initial bit into the groove. | | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | It took me 4 hrs to get the upper crank seal out. Wow. It was just fallen apart on me, took it out strand by strand. I fitted the new one just to try out on the lower bearing cap. Is it normal for the gasket seal (from Best Gasket) to stick out 1/8 above the groove of the bearing cap. The original was flush with the cap. I'm never done one of these and don't want to do it over in a few weeks from now. The engine is a 235 off a 53 GMC | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The seal needs to be trimmed once it is fitted in place. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is it normal for the gasket seal (from Best Gasket) to stick out 1/8 above the groove of the bearing cap. "Best gasket" brand has instructions you should follow. There is a guide in the kit for trimming the ends to the right length.
